I am using a TDS5104B DPO and an Agilent 66000 series of DC Power Modules, among many other peices of equipment. I am trying to interface these two via Test Stand 4.0 and NI supplied IVI drivers (V 1.21 for the DPO and V 2.2 for the DC Modules). HOWEVER anything I try from Test Stand results in an an error for these two peices of equipment. The error states that InitWithOptions failed, caused by IdQuery. I verify this in LabView via CIN, I get an error when IdQuery is true, no error when it is false. Is there a way in MAX to set the idQuery to false? Or another method of avoiding this error? I would much rather call this equipment from Test Stand than have to call an Action Statement and use LabView.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
