NI TestStand
If you save an object reference to "File Globals", does that memory get reallocated after the sequence ends?
I am saving object references to "File Globals" and I was wondering if the memory space allocated for these items was automatically reallocated back after the execution ends.
(3,081 Views)
Once finished with the object set the variable to equal to Nothing
eg FileGlobals.PropObj = Nothing
Regards
Ray Farmer
(3,072 Views)
Is there a command to set all objects in FileGlobals to nothing or do we have to right expressions for all of them?
(3,068 Views)
File globals should get cleared automatically when the execution completes (not just an iteration of the uut loop, but the entire execution must complete). If you are seeing otherwise please let us know and let us know which version of TestStand you are using.
Hope this helps,
-Doug
(3,063 Views)
