NI TestStand
Unknown variable or property name stationGlobals.Revision
I am having problems with a stationGlobals variable on one deployed system in the field. I stop on that step on the development system and the deployment system here in the lab and the variable exists.
On the system having the problem the station options was not pointing to the correct location for the stationGlobals.ini. So I had them change the cfg preference and sent them a copy of the stationGlobals.ini file. They rebooted the system but the error persists.
Sure would appreciate your thoughts on this.
jh
(3,728 Views)
Is the ini file in a location where your search directories can find it?  If not then you'll get that message.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,722 Views)
Thanks for the post. It turns out that the .ini file was overwritten when the station options were changed on the deployment system. They were changed to alleviate the problem I addressed in my Station options not copied to deployment post.
jh
(3,718 Views)
JH, your link appears to be a dead post, is there another post you should be referring too.
Regards
Ray Farmer
(3,708 Views)
(3,702 Views)
