In TestStand 2013, how to add some simple description messages
    hi ,guys.
   I want to add some message of test sample in the begin of the report, what can I do?
(3,946 Views)
Such as, I wand to add the file number in the begin of the report, what am I need set whilch operate?
(3,694 Views)
(3,694 Views)
    Thinks! Oli_Wachno
    yeah, I had checked the whitepaper, I known add the messages by configure >> report options. But I want to know how to transfer the data flows between Test execution and UUT Result data, so that I more understand theory how are the result data display to report.
(3,694 Views)
In this case, you should start with how the result collection works. Cause the results are what the result is based on.
(3,694 Views)
Thank you, Oli_Wachno.
Let me try it.
(3,694 Views)
