Hi James,
The quit button is on the UI loaded and operated by the DLL.
When it is pressed the step that calls the function from the DLL fails and its post action is "Go to cleanup".
By the way, I have been running my sequence (even into deeper levels of the sequence) for a while with the global load option still set to "Load dynamically" and it makes my DLL get unloaded at the end.
Although I am not quite compfortable with the situation I cannot stop and think why, because I have to finish coding it.
Ironically, I started to like the idea of keeping the DLL loaded because it keeps my "event log" panel displayed at the end of the test execution and this provides the operator some insight if something goes wrong
S. Eren BALCI
IMESTEK
