Initializing arrays with non-default values
I have a large array (300+ elements) and want it to be filled with all -1 at the start and not with 0.
A couple of (bad) ideas of mine:
- using an expression "array[0] = -1, array[1] = -1, ..." (a lot of typing work)
- using a for loop with an expression "array[Locals.k] = -1" (very slow)
- getting the array from "somewhere else" like e.g. a LabVIEW VI (cumbersome)
Is there some expression syntax I can use?
(3,891 Views)
You can use SetElements(Locals.d,-1)  where d is the array.
(3,855 Views)
