Installer created via Deployment Utility - disable uninstall before install?
With an Installer created by the TestStand 3.1 Deployment Utility, when the Installer executes it always has to first uninstall any deployed files that are on the target system.  If I wanted to disable this feature and have the Installer just always overwrite existing files is there a way to do so?
(3,162 Views)
Hi Snood1,
I was able to reproduce that message on my end here and unfortunately could not find a way to prevent that message or auto-uninstall.  I tried using the command prompt, but could not get a silent uninstall to occur.  I did however try it out on both TestStand 3.5 and 4.0 and each of these versions recognized that I was upgrading my deployment and installed over the old system with the new versions of the files.  The only thing I know to recommend here is an upgrade of the version of TestStand if you want to prevent this message.  If needed, click here for product information.
Best of luck!
Chris R.
(3,123 Views)
Thanks for the reply.  I may just have to live with this for a while because upgrading may not be possible for a while.  But at least I know the issue has been improved on in later versions.
(3,103 Views)
