NI TestStand
Installing runtime only for TS 2016 f1
What is the procedure for installing Teststand 2016 f1 runtime-only, separately from a test program deployment?  Do I run TestStandRTE2016-32.exe (409 MB) followed by TS2016f1Patch.exe (463 MB)?
Thanks.   -Joe
Joe Czapski, Sonos, Boston, Mass.
(3,142 Views)
Accepted by topic author Station3
Yes, you'll need to install both the 2016 RTE and the 2016f1 patch.
Another option would be to build a "dummy" deployment with the deployment utility that just includes the TestStand Runtime. As long as you do this from a PC that already has the patch installed - it should include the patched runtime.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(3,110 Views)
