NI TestStand
Integration Testing using TestStand
Time ago, in a NI Demonstration I heard that Integration Testing of embedded C code units can be performed using TestStand. I was not able to ask to the presenter more about it. Is that possible or i misunderstand it?
(2,413 Views)
Hello BryanEspi
You can use code modules developed in C within TestStand. You could design your test sequence to test you C code modules.
Does this answer your question? Let me know if you have any more questions.
Fernando Becerra | Field Applications Engineer | National Instruments | CLA | CTD
(2,351 Views)
