NI TestStand
InteractiveArgs active X reference
How do I get the act x reference for an object of type Interactiveargs?  I'm trying to use the TS API to determine the loop count in real time.  Runstate.loopindex does not work in Singlepass mode.
thanks
(2,985 Views)
You can create a reference to InteractiveArgs by using the API method Engine.NewInteractiveArgs.
The RunState.LoopIndex is only active while a step is looping. i.e you have set the Loop action on the step.
Regards
Ray Farmer
Regards
Ray Farmer
(2,977 Views)
