NI TestStand
Why does this Conditional expression not evaluate?
Hello there,
I'm having some trouble with this conditional expression! I'd like the filename to be generated dependant on the model entry point i.e. Test UUT or Single Pass. Test UUT works as expected, Single Pass always returns the following:
<filename>_.txt
instead of
<filename>_[NO_UUT_SERIAL_NUM].txt
Here's the expression I use to build the full path name:
Locals.FullReportFileName  = PropertyExists( "RunState.Root.Locals.UUT.SerialNumber")  ? (Locals.ReportPath + Locals.ReportFileName + "_" + RunState.Root.Locals.UUT.SerialNumber + ".txt" )  : (Locals.ReportPath + Locals.ReportFileName + "_[NO_UUT_SERIAL_NUM]" + ".txt" )
Also, see attached seq.
Yeap, a real basic question.... what am I missing?
Chroma
Message 1 of 8
(4,438 Views)
Whoops....
LabVIEW 7.1.1
TestStand 3.5
XP SP2
Message 2 of 8
(4,432 Views)
Try changing the expression for a StrComp() as follows:
StrComp(Locals.FullReportFileName  = PropertyExists( "RunState.Root.Locals.UUT.SerialNumber")  , "") != 0
Regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 8
(4,417 Views)
Ray,
Thanks for your prompt reply - I though the board would be dead, what with NI Week so near!
Hmmm, I implemented what you suggested but it yields the same result. I'm surprised it returns the "-" character at all.
Any suggestions?
-Chroma
Message 4 of 8
(4,417 Views)
Ignore what I original responded with must have had brain fade.
Try
Locals.FullReportFileName  = ( PropertyExists( "RunState.Root.Locals.UUT.SerialNumber")  ? (Locals.ReportPath + Locals.ReportFileName + "_" + RunState.Root.Locals.UUT.SerialNumber + ".txt" )  : (Locals.ReportPath + Locals.ReportFileName + "_[NO_UUT_SERIAL_NUM]" + ".txt" ) )
That should do it, as it works for me in TS2.01
Regards
Ray Farmer
Regards
Ray Farmer
Message 5 of 8
(4,401 Views)
Ray,
Thanks for the update - yes, we all suffer from brain fade... it's just how often is the problem!
Hmmm, still no joy. I also tried this expression with brackets to no avail.
I'm using TS Engine 3.5.0.725, TS Sequence Editor 3.5.0.725
Using Test UUT yields SimpleReport_1234.txt, using Single Pass yields SimpleReport_.txt
I wonder if the expression parser has got trapped somewhere.... as it seems to be evaulating the first two components of the true case then halting......
-Chroma
Message 6 of 8
(4,392 Views)
Sorry about that but another brain fade, the reason why is because with both Test UUTs and Single Pass RunState.Root.Locals.UUT.SerialNumber still exists.
Test UUTs will have a serial number and Single Pass  will be empty. If you run with out the Process Model then it doesn't exists.
I attached an WORKing example. (got they in the end Smiley Very Happy)
Regards
Ray Farmer
Regards
Ray Farmer
Message 7 of 8
(4,379 Views)
Ah.... makes sense! Thanks for your trouble. Works fine in TS 3.5.
Chroma
Message 8 of 8
(4,374 Views)
