03-25-2014 04:59 AM - edited 03-25-2014 04:59 AM
Believ it or not, it is finally working on my computer.
Here's what I did:
1.) Checked the LV adapter settings as Daniel suggested --> the same on my computer
2.) Downloaded & ran Roderics example --> no errors.
4.) getting totally confused.... and felt stupid like hell.... ![]()
5.) Shut down TS (2013) and LV (2013)
6.) Opened Norberts example in LV2013 AND mass-compiled. Shut down LabVIEW & opened the .seq file using TS2013. Ran it and worked fine.
7.) see 4.) maybe even a bit more
8.) Opened my example (three different queue handling possibilities) in LV2013, mass-compiled. Ran it in 2013 and all went well
Being pragmatic, I regard this issue as solved.
For the files (and anyone hitting similar problems): I supect this issue to be caused by the usage of potentially mixed-version lvlibs. (2012 & 2013) and a potential issue using LV2012 VIs using TS 2013.
Thanks a lot for your help!
Cheers
Oli
06-11-2015 03:33 PM - edited 06-11-2015 03:58 PM
I am working on something similar with Oli and I don't want to create a new thread for this issue, so I would like to post my question here.
I have a VI obtain queue name. This VI is called both in LabVIEW and in TestStand. The issue I have is when I probe after the obtain queue I have different reference number. I use LabVIEW and TS 2010. The createnew? indicator returned false at the second time the VI is called.
Called from TestStand: UI_Surface_Queue - 0xD0900008
Called from LabVIEW: UI_Surface_Queue - 0xD0A00009
WIth this, I am not sure what the solution is. Please help me.
06-11-2015 04:49 PM
Nevermind, I have my case work. The reference number does not have to be the same.
I set the VI execution property>Preferred Execution System: user interface and it works.
