NI TestStand
Is it possible to create a distribution kit or executable file out of a Teststand sequence file that uses CVI standard prototypes?
How can i create an executable file or distribution kit of a sequence file in teststand?. I'm using CVI standard prototypes.
(3,191 Views)
If you want to distribute your sequence files to other machines, there are a few things you must consider.
1. Create a TestStand Run-Time Engine installer. You can do this by selecting Tools>>Run Engine Installation Wizard.
2. Distribute your Operator Interface.
3. Distrbute your code modules (in your case CVI) and sequences.
We do not have a tool similar to that of Assemble VIs for Distribution for CVI. You will need to ensure that all of your code is copied to the target machine and that TestStand is able to resolve the paths for where these files are located (i.e. Configure>>Search Directories).
PLEASE REFER TO THE CHAPTER IN THE TESTSTAND USER MANUAL TITLED "DISTRIBUING TESTSTAND".
(3,191 Views)
Explanding on Bobs reply.
You could use the Create Distribution kit in CVI to bundle your sequence file and CVI objects.
Regards
Ray Farmer
Regards
Ray Farmer
(3,191 Views)
