NI TestStand
Can I create a global custom step type, available for all sequence files through a single copy?
I would like to create a custom step type and make it available to any (new or existing) sequence file, without having to copy/paste it every time, to avoid maintenance problems...
(3,376 Views)
Hi Andre,
You need to create the custom step type in the station view rather in the sequence file view.
There's a step type button near the Users Button.
Click on this button then proceed in creating the custom step type as you would have done in the sequence file.
If you are using TS 1.0.x then the new step type will be added to the types palette.ini.
If you are using TS 2.0 then will be able generate a new group ini file to hold your custom step types.
Regard
Ray Farmer
Regards
Ray Farmer
(3,376 Views)
Hello Ray,
Sorry for my late reply, but still: thanks a lot for your help!
André
(3,376 Views)
