NI TestStand
Is there a way to read the version of a TestStand sequence file which is under source control?
We've just started evaluating TestStand 2.0 and I have a question regarding
its support for source version control:
Is there a "built-in" way for a sequence (or a DLL that uses the TestStand
ActiveX API) to programmatically determine the version of a sequence file?
One of our requirements is that there is a central database which contains
the current "approved" versions of various sequence files (stored by name).
Ideally, we'd like to be able to prevent a user from inadvertently running
an out of date version by comparing the version of the sequence file they
are running against the sequence file name's entry in the database at
runtime.
Is this possible with a
ny built-in TestStand mechanism?
Bob Rafuse
Etec Inc.
(4,539 Views)
Hello Bob,
In TestStand, the sequence file version is stored in RunState.SequenceFile.Data.Version. As far as I know, there is no "Built-In" method of preventing one sequence to be executed according to the sequence version. However, it is not complicated to create this functionality. You may modify the process model in order to query the database (using database step types) for the approved version and if it doesn't match with the property mentioned above, you may jump to the "END" (using a goto step).
If you don't want to change the process model, you may modify your sequence instead of the process model. In this case, you may include in the "Setup" Step Group, database steps to query your database and jump to the END if the versions don't match.
Robert
o Piacentini
(4,539 Views)
> functionality.
Sorry, I meant "built-in" meaning method to read the version. Looks like
its there. I have no problem adding the checking code to the process model.
Thanks!
Bob Rafuse
Etec Inc.
(4,539 Views)
Does this variable (RunState.SequenceFile.Data.Version) exist in TestStand 1.0.3? I was unable to access it.
(4,539 Views)
Hello John,
Unfortunatelly there is no version information on TS 1.0.3. SCC was introduced in TS 2.0. However, you can implement it on your files. Basically you can create a sequence file global to store the version, so all the sequences in this file will have access to this property.
Roberto Piacentini
www.ni.com/support
(4,539 Views)
