NI TestStand
Is it possible to get the user language directory with TestStand API?
I would like to get the user language directory  of TestStand (<TestStand>\Components\User\language\English) with the TestStand API, Is it possible?
Thanks for your help
JP
(2,942 Views)
JP,
There is not a method or property in the API that returns the language directory directly.
You can use the Engine.TestStandDirectory property and append the rest to the path to get it.
Engine.TestStandDirectory + \Components\User\Language\English.
Hope it helps.
(2,931 Views)
Thank you for your answer
That is exactly the solution I used bout I would have prefered Having the full path directly.
May be in a next version of TestStand
Thanks again
JP
(2,928 Views)
