Is it possible to get user input such as numeric data using test stand
(7,103 Views)
ya... Its possible to get user inputs... You can use the meaasge pop up step. In the message settings if you enable the Enable_Response_text check box in the options Tab you can get the user input string. Users response can be accessed from Step.Result.Response.
(7,096 Views)
how can you get the numerical data....
(7,090 Views)
use Str(Step.Result.Response, "%$d") will return the string to a numeric.
Regards
Ray Farmer
Regards
Ray Farmer
(7,084 Views)
you can get the input data as string...
In the post expression of the message pop up step U can convert the step.result.response to numeric by using the Val() function.
For example if you have a local called 'count' then your post expression could be like this.
Locals.count=val(step.result.response)
(7,083 Views)
thanks for explaining me this concept....
(7,067 Views)
