NI TestStand
Is there a way to down convert multiple sequence files at once?
I am searching for a way to down convert sequence files from 2012 to 2010. Looking  to do more then one at a time and would like to be able to down convert an entire folder.
Brian
(3,664 Views)
Accepted by BrianInTheForest
This can be accomplished using the TestStand API using the following method to perform the save for previous function:
RunState.SequenceFile.AsPropertyObjectFile.WriteFile(WriteFileFormat_TestStand45)
You would just need to obtain an array of sequence file references, which is probably most easily done through a code module (such as the Recursive File List VI in LabVIEW).  Be sure to call Engine.ReleaseSequenceFileEx on the references after performing the backsave.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,654 Views)
Thanks Al B.
Brian
(3,630 Views)
