Is there a way to separate testresults on the same BlockLevel in SequenceEditor for ATML 5.0 horizontal reports?
Hello.
I'd like to find a way to separate certain parts in the report by adding whitespace between them, while keeping them on the same blocklevel in the report. For example: Instead of having the result of the Main part of the sequence appear in one table in the report, I'd like to be able to have several separate tables, with whitespace between them, all on the same blocklevel. And I'd like a step I could add in the Sequence Editor to mark the border of these tables, so it's all done automatically.
Is there a way to do this?
I'm using TestStand 2012 and ATML 5.0 Standard report (tr5_horizontal.xsl)
Thank you for your help 🙂
(2,236 Views)
Hi BalintJuhasz,
You should be able to do this by editing the ATML style sheet (this is specified in the Configure >> Result Processing dialog for the ATML report type by clicking the options button to the right of the report listing in the dialog). This document walks through the basics of customizing these style sheets and links to some more detailed documentation as well.
(2,206 Views)
