NI TestStand
Is there any chance to change default value (0 now) for numeric data type?
Exacltly as in subject.
K
(4,082 Views)
Hi
i am not able to anwer it generally because i had no task for it.
but if your numeric data type is inside a custom data type (or it is a custom-datatype) then it is possible to set a "default" value for it.
Just set the default-value in the Type-Editor.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,073 Views)
MimiKLM,
I don't know of a way to modify the default value of built-in primitives as you create them (so, making a numeric Local variable default to a value other than 0). As Juergen mentioned, if you create a custom data type, you can set a default in the Type Editor.
Are you instead referring to setting a default value for a specific variable in your sequence? You can easily do this by simply setting a value in the Variables pane. For example, if I have a numeric Local variable called MyVar in my MainSequence, I can click on it in the Variables pane and set the value to any number I want, such as 3. This will change the default value of that variable.
(4,033 Views)
