NI TestStand
how to replace BUUT_GetNextUUTs with a vi?
I am using a custom OI for running a burn in test (batch mode)
I would like to write a vi to get the serial numbers and whether or not the slots are enabled
I believe the model uses
PreBatch
      Tell Dialog To Get Next UUTs
           BUUT_GetNextUUTs
for this purpose
the main problem is that BUUT_GetNextUUTs is not model to the OI and keeps getting stuck behind my OI front panel
if I write a vi to do this I can make it model to the vi
it appears that the modelsupport2.dll interfaces with Parameters.ModelData.DialogHandle
is there a way to do this with a vi?
(4,354 Views)
You can override the PreBatch callback in your test sequence.
Replace the "Tell Dialog To Get Next UUTs" step with the step which calls your custom vi.
(4,329 Views)
I am aware of which callback to override, I do not know how to return the information back to TestStand
If there was a cluster call NI_BatchModelData that could be passed back to TestStand from a vi, then  I could use that
I think trying to create this cluster from scratch would be difficult, time consuming, and error prone
(4,305 Views)
I think I found a solution
I don’t think I need to change all of the ModelData so I can use an approach like this
I wrote a vi that has all the serialnumbers as well as the continue test boolean
(4,300 Views)
