NI TestStand
It is possible to programmatically disable the "Executing Code Modules in an External Instance of CVI" feature?
It is possible to programmatically disable the "Executing Code Modules in an External Instance of CVI" feature within a CVI project?
I know how to do it manually (Configure > Adapters... > Adapter Configuration).
Thanks in advance,
--M
(2,819 Views)
Yes. TestStand 2.0 added the Engine.CVIAdapter_ExecuteStepsInCVI property.
(2,819 Views)
