NI TestStand
KeyFocus not working in VIs invoked via TestStand
Hello, when the LabVIEW adapter in Teststand is configured to Run-Time, then VIs invoked in a sequence which use the KeyFocus property node wont work properly - the key focus is never received by the control. It works fine when the adapter is set to Development System.
Is there a workaround?
Thank you
______
I found this topic which describes the same issue - it's from 2005 ??!!
https://forums.ni.com/t5/NI-TestStand/Key-Focus-does-not-function-in-LabView-when-invoked-via/m-p/29...
(2,056 Views)
I have also observed this.  I found that by having a 50ms wait before the keyfocus call, it will work for me.
(1,963 Views)
