LV VI Parameter not showing up in TestStand
I have a LV VI which simulates a DC waveform and outputs a basic measurement every time it runs.
My issue is when calling it in TestStand, the parameters doesn't seem to populate. I feel like I've connected all the necessary inputs/outputs for the connector pane, but maybe I am missing something.
(445 Views)
Can you attach the VI? It really just looks like nothing is hooked up to the connector pane. So I would think either.
  1. Things need to be hooked up to the connector pane
  2. Teststand is looking at an old version, and you updated a different version
(436 Views)
I addition, I recommend a few simple LabVIEW tutorials.
  • A "one iteration FOR loop" is the same as "no FOR loop" here.
  • Unless you expect the "offset" to change between iterations, the terminal belongs before the loop.
  • Your outputs seem a bit redundant. (3x  the same data)
  • A picture cannot show the configuration of express VIs or the contents of dynamic data wires, making it impossible to analyze. Does it work correctly if called outside of TestStand?
(432 Views)
