NI TestStand
[LV -> TS] How to execute a SEQ file, get the result (PASS/FAIL) and the report file ?
Hello j_dodek,
you might find a pre(c/v)ious attempt to use the old sequencer with
TS in this old post :
http://forums.ni.com/t5/NI-TestStand/Enqueue-Teststand-cluster-to-Labview-return-a-cluster-by/m-p/30...
Just remember that what I'm asking for is a VI
interface to TS that permit to transmit a SEQ
file to run, a UUT serial, get the result and the
report covers 99.8% of the cases someone
into unit testing would require.
That TS doesn't provide such a simple and
elementary interface is beyond comprehension.
The operator is not always to scan a UUT serial
into a dialog box, this can be provided by a
serial code server, hence the API interface
allowing to provide an optional UUT serial.
I can stand that TS allows very complex testing
scenario through the use of very complex
systems (sequencial or parallel batch) but
why rendering the most simple procedure
into an obnoxious development implying
data transfert and message passing.
It's been more than 6 months now that I just
want to try doing simple things with TS,
starting by communicating clusters into
containers (and vice versa) only to discover
that it cannot works.
Then using TS as a simple test engine
without all the fancy stuff around but again
it seems to be too simple, TS requiring
quite a complex testing allegory using
models and things just to execute steps
just to conclude if the unit is good or not.
I am frustrated that it takes so long to get
things done using the KISS principle, just
because NI wants to show some muscles.
Yeah, the old sequencer was quite enough,
it would just have required to add the
expected functionnalities, but I'm the
contractor, I was requested to switch from
the old sequencer to TS.
Something that would have required a
simple API wrapping reveals to be rather
difficult, not speaking about deployment
and relative path resolution.
But I digress...
EDIT : thanks for the 4th version of your C#
implementation. Could it be possible to get
the serial included in the report file name,
and also provide an optional report path
for the report generation ?
I do a ReleaseSequenceFileEx, but you
don't, is it because it is automatically handled
by the .Net GC ?
David Koch
Message 21 of 28
(3,509 Views)
Hi David
Sorry that i am not going to answer stuff from old thread, because i have to do a job as you, too.
Maybe the blue ones...
But your questions here:
UUT to reportfilename, You dont have to care in your code! It is a simple configuration of your station. Just enable it!
If using TS2014 take care use the right version 32 or 64bit (My Example is using 64. Normally i am using 32, so i was just wondering why missing
but great! working on both versions as well. This effort here will help me in future tasks!!)
The release stuff:
You are right. I have just forgotten it..
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 22 of 28
(3,497 Views)
Thanks, considering the informations you provided
me with, here's a modified version of the LV runner
that still requires some clean-up to do by removing
the dependencies to the 'RunState.Root.xxx' stuff 🙂
David Koch
Message 23 of 28
(3,490 Views)
Hi David,
well LV is not my first choice programming language.
So it is a little bit hard to understand whats going on.
Just a few things i wonder:
why do you need RunState.Roots stuff?
stuff between  NewExecution and WaitForEndEx ? Looking really Strange! but when playing with true/false
there is a cominbation everything is "empty"
You are creating your report path as well, too. Sorry understand that, even if comments are not french.
I would recommend to remove all that.
Try to get LV running in a way like my example.
That means configuring the ReportPath in TestStand via SequenceEditor for your maschine.
if this is running. Let start disscussion again if it is still necessary to define ResultOptions via LV
Please tell me which TS Version you are using and which model "Type" the legacy or the plug-in one.
Regards
Juergen
--Signature--
Message 24 of 28
(3,484 Views)
Hello again 🙂 Well, basically I'd like to have to do
with TS as little as possible, hence configure and
set things from LV would be perfect.
I'm not the one who chose the LV path, I'm a text
coder as well, but the legacy code here was in LV.
I'll do some clean-up and testing and get you
informed of the results.
EDIT : LV 2013 and TS 2014
David Koch
Message 25 of 28
(3,480 Views)
Accepted by topic author Kochise
Here we go, final release of the VI, it seems to work,
I still have some trouble configuring 'ReportOptions'
on the fly to keep only errors in the report.
David Koch
Message 26 of 28
(3,354 Views)
In order to work correctly, here are the 'Cfg' files
you need to place in the following folder on your
development or deployment machine :
c:\ProgramData\National Instruments\TestStand 2014 (32-bit)\Cfg\
David Koch
Message 27 of 28
(3,225 Views)
Hi
I was on holyday.
Task still open?
Juergen
--Signature--
Message 28 of 28
(3,142 Views)
