LabVIEW Time Stamp not handled properly in TestStand
TestStand is interoperating LabVIEW time stamp of 12:00:00PM as 00:00:00 PM.  I will return false for the following expression from the same day 12:00:00PM > 11:59:00 AM.  See my attached example, I feel both test should pass.  I am using TS2010 and LV2010 I saved to earlier versions so more people will be able to evaluate the code.
Herrlin
Just trying to spread the LabVIEW love.
(3,771 Views)
Why don't you convert the timestamp to a numeric 'seconds' value and do the evaluation on that?
CTA, CLA, MTFBWY
(3,751 Views)
I am also loging my results and I wanted the time stamp to be human readable.  However, I did end up send both the double and time stamp type to TestStand as a work around.  So thanks for the good idea.  I still would like to know why 12pm shows up as 00pm in TS.
Herrlin
(3,746 Views)
Comparing string values for numeric values is dangerous.  For example, "10" > "1" returns false, since "1" comes before "10" alphabetically sorted.  It is highly discouraged.
I have reported the issue for displaying noon as 0:00:00 PM rather than 12:00:00 PM to R&D to investigate and hopefully fix in a future version of TestStand.
(3,732 Views)
AllenP
I agree with the danger of comparing strings now that I am better educated on the subject.  Thanks for the reply and reporting the issue to R&D for me.
Herrlin
(3,717 Views)
