I am using LabVIEW to create my test report for TestStand and wanted to carry over the numeric formating from TS steps. The problem I run into is that TS and LabVIEW don't follow the same format syntax.
For example in TS to convert to an integer is %i and LV it is %d. TestStand also has syntax "$" and "#" which LV doesn't understand.
# - means show decimal point or radix
$ - means show trailing zeros
When I wire the numeric format from the TS property directly the LV format to string function I get errors. My bandaid fix is the do a search and replace on the different conditions mentioned.
I was going to put this in the bug report/ new feature request link, but couldn't find it.
