NI TestStand
change default value of variables
How do I change the default value of parameters shown in the Step setting pane. I am using TestStand 4.0. Its obvious how to change the current value but if I check the Default box, TestStand populates this with some original value...???
(4,306 Views)
Assuming this step runs a Labview VI, you change the default value right at the front panel of the VI itself. Not within Teststand.
(4,296 Views)
So if I have no default value set in the LV VI why does TestStand persistantly show me an old default value when the default button is checked.
(4,289 Views)
There is always a default value set in Labview, you should go check to see what this is.
Right click on the control in labview on the front panel, click Data Operations --> Reinitialize to default value
To set a new default value, enter a new value on the control then right click on it, click Data Operations --> Make current value default
(4,285 Views)
Don't forget to save the vi and reload the prototype in TestStand.Smiley Wink
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,276 Views)
