LabVIEW or Python with TestStand
I am pretty strong in both LabVIEW and Python, but a newbie with TestStand.  My Quality group wants me to use a text based language, but I may be able to talk them into accepting LabVIEW if I limit the updates on the VIs.  I suspect the integration with TestStand is much better with LabVIEW than with Python.  Assuming I have equavalent proficiency in Python and LabVIEW, will it be twice as much work building a test flow with TestStand if I use Python?
(4,731 Views)
Hi j_osh_o,
Have you checked out the Developer Zone article on Using IronPython with TestStand
Hassan Atassi
Senior Group Manager, Digital Support
(4,700 Views)
The work load is split into test management functions in TestStand, and data acquisition and analysis functions in your IDE. The work in TestStand should be about the same. Assuming you have equavalent proficiency in Python and LabVIEW, the difference would be how hard is it to do the required tasks in LabVIEW vs. Python.
cc
(4,666 Views)
One more thing, I don't know this first hand, but you are most surely correct that the integration is better with LabVIEW. Because of this there will be some setup time associated with Python that you won't have with LabVIEW. There'll also be many more forum members with LabVIEW+TestStand experience.
cc
(4,665 Views)
There are open source Python tools for use within LabVIEW:
http://labpython.sourceforge.net/
(4,660 Views)
