NI TestStand
Labview get TestStand step result
Hi,my goal is to get each TestStand Step(Multiple /Numeric Limit Test) Result from LabVIEW OI,includes Step Limits ,Data.
How can i do?
thanks!
mason lu
(5,008 Views)
Hi Mason! I'm not quite sure what you're asking. You have an Operator Interface in LabVIEW, and you want to see each step data and limit in that operater interface?
(4,980 Views)
Hello Chantastic,
Yes,I have an Operator Interface in LabVIEW, and i want to see each step data and limit in that operater interface
Please,give some advices!
ThankQ!
(4,971 Views)
If your Operator Interface includes the test report, you can modify the test report to display the relevant information. See the TestStand Manual link I'm including below. There is a specific option called "include test Limits"
Report Options Dialog Box
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/report-options-dialog-box.ht...
(4,927 Views)
In the past, I've used a custom UI message.
Here's a tutorial: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3tWCAQ&l=en-US
For example, after a Numeric step (or in the SequenceFilePostStep Callback) send your UI a custom message with something like "Measurement_HighLimit_LowLimit" and then in your UI, you need to parse that string and handle the information.
Pulido Technologies LLC
(4,915 Views)
