NI TestStand
Write or read to Excel from TestStand
Does anyone has an example sequence in Test Stand for read or write to an Excel sheet by using the Microsoft Excel Object library?
Message 1 of 13
(11,550 Views)
Message 2 of 13
(11,549 Views)
Thank you for the quick response, but the example has been made by using a LabView code. I could also make it with VB (not a LabView user), but I would like use Microsoft Excel Object Library directly from Test Stand. It should be possible shouldn't it?
Cheers
Message 3 of 13
(11,548 Views)
There is an example in the TestStand Examples folder under LoadingLimits maybe that will help. The VB example may help.
You should be able to access the Excel Methods and Properties via the ActiveX Adapter.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 13
(11,539 Views)
Yes that's what I use (Excel Methods and Properties via the ActiveX Adapter). I only tried to get an example if someone already did it. It's ok now, I succeeded yesterday in making it.
Thank you anyway for helping me.
Igor
Message 5 of 13
(11,527 Views)
Hi Ray,
I tried the link you listed but I'm using LabVIEW 8.5 and the VI you give is 5.1.
It says it cannot convert 5.1 to 8.5.  Is there a way around this or failing that do you know if there is a new link?
TIA,
Sean
Message 6 of 13
(10,912 Views)
Hi Igor:
Do you still have the seq that reads/writeto Excel from TestStand via the ActiveX adapter? If so, would you mind sharing it?
Thanks.
Mim
Message 7 of 13
(10,818 Views)
Hi Mim,
Sorry for my late response.
Please find the example here. I hope it helps you.
Igor
Message 8 of 13
(10,742 Views)
Hi Igor:
Thanks for posting the example.
I am getting errors for step 1 (print screen is attached). Any comments on why? I am working with TS 4.1.1.
Thank you,
Mim
Message 9 of 13
(10,731 Views)
Sorry Mim if I can help but I am not using personally Test Stand anymore.
I think you haven't put correct reference to your Excel file.
This is example but you have to fill the variables correctly
Message 10 of 13
(10,723 Views)
