Launch TestStand failed
Yes but by this utility is not uninstalling softwares the same way Windows does, so maybe this could help. We should give it a try.
Message 11 of 19
(1,896 Views)
Sfl,
Please uninstall all versions of TestStand from your machine, then use Windows Explorer to browse to C:\WINDOWS\assembly. Go to the View menu and select Details. Scroll down to the NationalInstruments files and provide screenshots of all the NationalInstruments.TestStand.x files.
Thank you.
Manooch H.
Message 12 of 19
(1,889 Views)
Here are two files of expected assembly :
one with TestStand V4.1 installed
one with no TestStand installed
Regards.
Message 13 of 19
(1,884 Views)
Thanks Sfl,
Could you also provide a screenshot of the error that you receive when you attempt to launch TestStand 4.1?
Thank you.
Manooch H.
Message 14 of 19
(1,882 Views)
Attached is the error (come just after the yellow rectangle with TestStand 4.1 disappeared)
Message 15 of 19
(1,880 Views)
sfl,
I think I know what the problem is. I think your sequence editor layout file got corrupted when the process crashed. That file is not uninstalled by the uninstaller. You need to manually remove it.  The file is called layout_current.bin and it is located in the following directory:
<User Directory>\AppData\Local\National Instruments\TestStand x.x
You can also delete the other files in that directory if you want to restore the default settings for the sequence editor and user interfaces.
Hope this helps,
-Doug
Message 16 of 19
(1,867 Views)
Sfl,
Please let us know if removing the sequence editor layout file corrects this problem. Thank you.
Manooch H.
Message 17 of 19
(1,833 Views)
To everybody : thank you very much for your support, TestStand V4.1 is now installed and seems to be operationnal.
Regards.
Message 18 of 19
(1,816 Views)
Well, thanks for your feedback !
Great to know that everything is ok !
Have a nice day !
Message 19 of 19
(1,813 Views)
