NI TestStand
Loading appropriate process model from specified .env
I have two envs, one is for debug use and the other is for production use. The debug env uses "debug_batchmodel" and the production uses "batchmodel". Is there a way to force TS to use the correct model for the specific env? In other words, I want to use the "debug_batchmodel" when I am in the debug environment and use the "batchmodel" when I am in the production environment. It keeps loading the last model I use.
Thank you.
(1,771 Views)
Add SequenceFileLoad callback to your client sequence.  In the callback, add an if block to check if you are using the debug environment; if you are using the debug environment then using TestStand API set the Engine Station Model to your debug model otherwise set it your production model.
(1,740 Views)
Accepted by TTLN4
Hi ee-jallen,
Thank you for the quick response...
So I added SequenceFileLoad to both batch models (production and debug). Each model will read a .ini file to determine if it should use debug or production but the debug model doesn't get loaded using the statements below. What do you think I am missing? The production model does, however.
if debug:
RunState.Engine.StationOptions.AllowOtherModels = True,
RunState.Engine.StationOptions.StationModelSequenceFilePath = "C:\\Project_Path\\Process Model\\BatchModel_DEBUG.seq",
RunState.Engine.StationOptions.UseStationModel = True
else:
RunState.Engine.StationOptions.StationModelSequenceFilePath = "C:\\Project_Path\\Process Mode\\BatchModel.seq",
(1,718 Views)
Accepted by TTLN4
Put the callback in your normal client sequence not in the process models.  Also if you have two different environments that can be loaded, you can just check which environment is in use with.
RunState.Engine.GetEnvironmentPath() == "[replace with your path to debug environment file]"
I just used your code from your post with a conditional that checks the environment path/file and I was able to branch into the if or the else condition and set different process models.
(1,715 Views)
Thank you. That works.
(1,700 Views)
