Log report/database failed
If teststand cannot write de log files/database is there an option that teststand will write the log files when the network is available?
(2,308 Views)
The Offline Results Processing Utility can be used for this:
https://zone.ni.com/reference/en-XX/help/370052R-01/TOC49.htm
Hope this helps!
Trent
(2,287 Views)
