Logging individual sequence result?
Hello All
I have a requirement where i need to get results of sequence execution into the my custom database. My sequences are designed in such a way that high level sequence [Say Seq_1] has only "SequenceCall" steps which are further calling other sequences.
Ex:Sequence levels are as below:
            Seq_1
                   Seq_1.1
                           Seq_1.1.1
                           Seq_1.1.2
                   Seq_1.2
                           Seq_1.2.1
                           Seq_1.2.2
Problem:
I need to get result of sequence execution of each level into my DB seperately in a new row.
Please find below columns in DB schema
Ex:
TestID    UUT_NUMBER      UUT_STATUS   Report_FILEPATH
1             1.0                         Passed               "......"
1.1          1.0                         Passed               "......"
1.1.1       1.0                         Passed               "......"
1.1.2       1.0                         Passed               "......"
I am able to get the TestID and but not sure how do i retrieve the UUT_STATUS or Sequence execution status for each level into  my database.
Please respond asap, as this is little urgent for me.
Regards
NG
(3,494 Views)
Can someone give suggestions on this, its really critical for me.
Regards
Goel
(3,469 Views)
It's StepResult.TS.SequenceCall. You could have looked at the default schema and found this. If you had used the default scehma, all you would have had to do is a query to generate the report. You still seem to think that the design of the database has to be identical to a report. Have you consulted with a db administrator?
(3,457 Views)
Thanks for reply Dennis
Actually, i forgot to mention about that i need to confiure Logging in such a way that if i run Individual lower level sequence[Seq_1.1.1] or run a higher level sequence[Seq_1], in both the cases results should get logged to DB.
(3,436 Views)
As long as you use the same process model, what difference does it make?
(3,427 Views)
