NI TestStand
Logging to Teststand log
I am running a test sequence.  How do I log from the test sequence to the Teststand datalog?
(3,078 Views)
Accepted by kerugoya
You need to enable Database logging in the Configure | Database Options... menu item.
Check the section in the Reference Manual, there is a tutorial how to set this up and also checkout the example in the TestStand / Example Folder.
Regards
Ray Farmer
(3,070 Views)
