Looping through parallel model starts at index 1 instead of 0 on second execution
Hello forum
I have an issue with looping through the UUT loop. Even though I configured the loop to start at 0 it starts at 1 from the second time I start the test without stopping and restarting the sequence. I attached the modification to the process model as a screenshot.
Thanks for any help!
Raphael
Message 1 of 10
(4,876 Views)
What is you purpose exactly ?
Test only 3 UUT on a socket, and then stop the socket execution ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 2 of 10
(4,850 Views)
yes, loop three times then stop and wait for the next start command from the GUI.
Message 3 of 10
(4,843 Views)
Accepted by raphael.wittwer
Why do you keep the counter in a SG ?
This loop is for a specific socket to run as much as needed. If you keep a counter as normal, but use a variable (local) to set the max number of loops I guess you won't have any problems.
From what I see, it should work, but keeping the counter in a SG sounds weird to me.
Message 4 of 10
(4,832 Views)
The idea behind the station global was that after a crash the sequence would start with the right batch, but as it is now I don't need this functionality. I will try a normal local variable and see what happens.
Thanks!
Message 5 of 10
(4,827 Views)
HI Raphael,
 just ran into this few days ago : in case of a crash (meaning complete app crash or PC being unplugged for example) there is a chance that your SG won't be saved !
Indeed SG are saved whne the Engine shuts down or if you call a specific Commit method.
See here : https://www.ni.com/docs/en-US/bundle/teststand/page/station-global-variables.html
Message 6 of 10
(4,823 Views)
I tried locals for this counter and propagated it through the sequences, unfortunately this has the side effect that the sequence starts running without user input. I undid the change since this seemingly breaks other things.
I will need to find a point to reset this counter since the loop does not work as I expected, probably right after the GUI is called.
Message 7 of 10
(4,817 Views)
I tried today reinitialising the for loop after the GUI gets called, unfortunately this does not change anything. The "first" iteration still is 1 instead of 0 on the second pass. On top of that I noticed that the loop counter goes up to 4, which should be impossible with the parameters from above.
Message 8 of 10
(4,790 Views)
the solution was to use Locals.xy and propagate them into and from the sequences. What was missing the first time I tried was the parallel model was still using the state from the station global instead of the local which led to unexpected behaviour.
Thanks for your help!
Message 9 of 10
(4,786 Views)
I didn't do much !
Glad you found a solution ! 🙂
Message 10 of 10
(4,783 Views)
