NI TestStand
Make The Horizontal XML Stylesheet Expandable
How can I make the Horizontal stylesheet expandable?  I've gone through the knowledgebase articles below, and tried modifying appropriate sections of the horizontal stylesheet, but haven't had any luck.  I usually end up with an empty report.
http://zone.ni.com/reference/en-XX/help/370052J-01/tssuppref/infotopics/report_stylesheets_details/
http://digital.ni.com/public.nsf/allkb/EC64D7C24421A2E58625751D00491809
I've also tried modifying the expandable stylesheet to make it look more like the horizontal stylesheet, but I couldn't get that to work either.  Does anyone have any recommendations or alternative stylesheets that may be easier to modify?
(3,017 Views)
Hi xiv015,
The implementation of having expandable report sections in the expand.xsl has some overhead involved in creating the Document Object Model for those sections. If it is cosmetic changes that you would like to make to the expand.xsl to get a closer appearance to the horizontal stylesheet then some suggestions can be found in the Customizing TestStand Style Sheets section of the TestStand Help.
Milan
(2,989 Views)
