NI TestStand
Unable to run Excel_run_macro after pass/fail report generation step
I am using TestStand 4.2.1 to create a test sequence. I used a sequence call - Excel_Run_Macro- to copy some data from a excel sheet (Temp_PRCR.xls) to another excel sheet (PRCR_Run_Macro_TARGET.xls) and save it as another excel file (PRCR_Run_Macro_TARGET_Out.xls). It works properly with this single step. But it's not work after a pass/fail report generatation step. Even the new file is not created in this case. I put a delay time (5second) in between it create the new excel file but it didn't copy the data properly.
(3,005 Views)
Is the new step putting additional data into the Excel sheet or modifying it in any way? The new step would seem like a red herring if it wasn't interacting with the Excel sheet.
CTA, CLA, MTFBWY
(2,987 Views)
