NI TestStand
Mass Compile :TestStand - Default Values 90.llb ???
I'm using Labview 2009 and TestStand 4.1.1(using the Labview Runtime Engine 9.0 Adaptor), and get the following error when running my sequence file:
Error, The support VI 'C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.1.1\AdapterSupport\LabVIEW\TestStand - Default Values 90.llb\TestStand - Get Control Default Value.vi' might not be up to date. Please update llb file to the most recent LabVIEW version. LabVIEW: VI version is too early to convert to the current LabVIEW version. [Error Code: -17500, Operation Failed.]
As I did not have this llb, I've copied and renamed the "TestStand - Default Values 86.llb".
After opening TestStand - Default Values 90.llb, Labview does not allow me to save the changes as it is password protected.
Anyone have any advice on this matter?
(3,372 Views)
Are you sure it is not just Read-Only?  I noticed my previous versions 'TestStand - Default Values 90.llb' was read only, I had to change that and then update for the VI for LV 2010.  Renamed it to TestStand - Default Values 100.llb.
Try opening the LLB directly, I have never had any problems doing this.
PH
(3,370 Views)
