NI TestStand
Measurement & Automation Programming Guide or Manual
I have the responsibility of supporting testers using the subject software, under TestStand. What I have seen looks like a block diagram of elements that the programmer can modify, select, etc. I need to learn how to use this. So, any guides, manuals, advice, etc. would be appreciated greatly. I can be reached at 507.453.4937, and/or Joe Roberts, POB 5025, Winona, MN 55987-5025 mailing addr.
Thanks - Joe
(3,298 Views)
Wow, where to start.
TestStand is a test sequencer. Most people who use TestStand use it to run tests that were created in other applications. Most of the time it is LabVIEW, LabWindows/CVI, or C/C++. Some testing can be accomplished natively in TestStand. So lets start by getting you some documents:
Start Here
TestStand Manuals
TestStand Demonstrations
I would like to give you more help. Could you give a better idea about what you have, what you have to use it for, and what information you are looking for?
(3,281 Views)
Bob -
Thanks for the documents and reply!!
To be more specific, I observed what appears to be something like a block diagram, where elements can be altered, or value selected, and moved around in various "boxes". It is in "Measurement & Automation". I need to know what this is, and how to use it.
Thanks - Joe
507.453.4937
(3,274 Views)
Hi Joe,
Is it possible to post an image (jpg) of this diagram?
Regards
Ray
Regards
Ray Farmer
(3,270 Views)
