NI TestStand
Message Box Format With Hyphens
I want to use a Message Box which will skip over the hyphens similar to the attached file. After all the numbers are entered, the numbers shall have the hyphens. How can I do this?
(2,171 Views)
This isn't a feature implemented in the code for the message popup step. You have to implement your own module providing such feature.
Norbert
Expert: Geometry
(2,147 Views)
