NI TestStand
Message Popup - making it fixed size?
I'm wondering if there is a way to make the default message popup a fixed size?  I have different error message boxes and subsequently, they are all different sizes.  Anyone know a relatively easy way of doing this?  creating a custom step is not preferred.
thanks
[DL]
(2,991 Views)
Accepted by DanielJL
Hi DanielJL,
There isn't a way to make the default popup a fixed size. However, as you mentioned, this can be done relatively easily through a LabVIEW Action Step (or other adapter). If you need help knowing how to do that, feel free to let us know.
Best,
John M
Applications Engineer
(2,969 Views)
