Message popup response string
I store the response string from message pop using
Locals.ResponseValue= AbsVal(Step.Result.Response))
ResponseValue should be numeric (between 0 to 999), how to test if response entered is string?
CLD
(4,349 Views)
Edit to original post:
Checking to see if VAL() returned 0. If zero then not a valid number. Only issue that it will ignore 0 also.
Not sure if there is a better way to do this?
TIA.
CLD
(4,346 Views)
Accepted by lvrat
you could check if this condition is true:
Str(Val(x))==x
this will return true for valid numbers, false for anything else.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(4,342 Views)
