NI TestStand
Migrating Teststand3.1 to Teststand 2016
Hi All,
I have a requirement where I need to Migrate Teststand project built on 2.0 and 3.1 to Teststand 2016 SP1.
I wanted to know which is the best approach I can take for migration. If you give me some procedure it would be helpful.
I tried to open the sequence files and run it. Ended up with lot of station global variables and local variables errors ,Logging and code modules errors.
My current system setup:
Teststand :2016 SP1(64bit)
Labview:2017 (32bit)
Windows 7(64bit-OS)
Older code:
Teststand 2.1
Labview 7.1
Windows xp(not sure exact version).
Anand
(2,281 Views)
Not sure if you read through this: https://www.ni.com/en/support/documentation/supplemental/13/migrating-to-the-current-version-of-test...
It may be helpful.
The other problem you are going to have is taking the LabVIEW code from 7.1 to 2017.  I think you have to convert it to 8.x first.  Here is a tutorial on converting LabVIEW: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YSO4CAO&l=en-US
If there is a chance you can post your sequence file I could look at it on my end.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,268 Views)
