Mismatched items or unmatched item Error Code: TS_Err_MismatchedItems–(Value: -17348)
I create a TS Seq File with a LV VI.
sometimes (not very often) i get the error code: TS_Err_MismatchedItems–(Value: -17348)
has anyone an idea why this error occurs?
regards
Timo
Message 1 of 10
(5,094 Views)
Hi Timo,
What are you passing to/from your VI?
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 10
(5,087 Views)
Hi Ray
i use the VIs to build the TS Seq File,
the VI  creates a subsequence where the first step of the subseq is a "wait step".
when i run the mainsequence => sequencecall => wait step the error occurs
sincerely
timo
Message 3 of 10
(5,085 Views)
detailed error description:
Details:
The sequence '[0] GRUNDEINSTELLUNG' contain a step that begins or ends a block that is not completed by a corresponding step.
Error Code:
-17348; Mismatched items or unmatched item.
Step 'Wait (2.000 sec)' of sequence '[0] GRUNDEINSTELLUNG' in '101.seq'
It doesn, t matter what s the first step in the sub seq:
Message 4 of 10
(5,083 Views)
Hi Timo,
How are you creating the Sequence(s) and step(s), are you using the types palette or cloning from a template sequencefile (a sequencefile with a set of steps to use)?
Regards
Ray Farmer
Regards
Ray Farmer
Message 5 of 10
(5,076 Views)
Hi Ray
I neither use sequence template nor the type palette.
I use LV to create the TS Seq file, using the TS ActiveX Engine (Class: TS.IEngine)
(=>thx to the  TS API Reference Poster)
i attached a section of my LV program:
Message 6 of 10
(5,062 Views)
Hi Timo,
I modified your main VI by taking out the missing VI's from the case statement so that the main would run. I also created a sequence file which just contained the MainSequence.
When I ran the create seq file_mod.vi, it inserted an NI_WAIT step into the Main group of MainSequence and saved the Sequence File with out any errors.
Is it possible to send the missing vi's especially the Insert_grundeinstellung.vi.
Regards
Ray Farmer
Regards
Ray Farmer
Message 7 of 10
(5,019 Views)
hi Ray,
thx for your great efforts
I will post the seq file, where the error occurs, tomorrow
Eastermonday and Good Friday are public holidays in germany - so I m out of the office and stoped working on my diploma thesis for four days. Smiley Wink
Happy Easter
Timo
Message 8 of 10
(5,014 Views)
problem solved Smiley Very Happy
an END STEP was insered, but no IF Step !
Message 9 of 10
(4,994 Views)
Thats great news.Smiley HappySmiley HappySmiley Happy
Regards
Ray Farmer
Regards
Ray Farmer
Message 10 of 10
(4,989 Views)
