NI TestStand
Missing UUT Report Operator
That string is rendered by the HTML report.  My guess is if the string is empty then it will throw No Operator Logged In on the report.
Did you try the beginning of the entry point with the sequential model and not your modified model?  I believe that something in your model is changing the operator to Null somehow.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 13
(981 Views)
Accepted by mrbean
Any update ?
Message 12 of 13
(973 Views)
I am definitely blowing away the RunState.Root.Locals.StationInfo.LoginName (which turns out to be the critical variable in displaying the Operator in the header).  I think I have tracked down the culprit.  I appreciate all the help.
Message 13 of 13
(963 Views)
