NI TestStand
Model Options cannot launch in TestStand
Hi guys
When I choose the Model Options of configure ,I would set the number of socket  ,But cannot launch that options ,
show error  as the attached  picture .
 Please help me ,thanks a lot
(2,716 Views)
The Model Options selection runs a Configuration Entry Point in your process model, which is throwing an error. You should reach out to whoever wrote your custom process model (Phoenix.seq by the looks of the screenshot).
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,691 Views)
Hi WireWeaver
Thanks for you help  ,I fixed the issue . just delete the TestStandModelModelOptions.ini of  TestSTand Cfg folder .and try again launch the Model Options .
(2,687 Views)
