NI TestStand
How do I change a pass/fail test to an action
Before I knew the difference, I selected 'pass/fail test' for one of my steps, when I should have selected 'Action'. Everything concerning the test is correct, I just don't want it to pass/fail. The two steps where I made this mistake, simply need to be changed to an Action. Is there a simple way to do this, or do I have to re-enter all the info again for the action, then delete the test.
(3,972 Views)
If you double click on the step then click on change step type, you will be able to change the type of step there.
Brian
(3,970 Views)
Updated answer (more recent versions of TestStand): Click on the step, go to the properties page, and select "General".  The next column will have the Type (among other things) and you can change it to action.  🙂
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,114 Views)
