NI TestStand
Running teststand sequence on windows terminal withought opening testastand and getting all report on ternimal only
Is it possible to run teststand sequence on terminal and get sequence pass/fail result on terminal itself like running python scripts on terminal and getting results on terminal itself
(3,148 Views)
Yes - see the help document here:
Configuring Sequence Editor and User Interface Startup Options
 The command and response will look something like this:
C:\Users\Public\Documents\National Instruments\TestStand 2016 (64-bit)\UserInter
faces\Simple\CVI\Source Code\x64>TestExec /runEntryPoint "Single Pass" "C:\Users
\Public\Documents\National Instruments\TestStand 2016 (64-bit)\Examples\Demos\Co
mputer Motherboard Test\CVI\Computer Motherboard Test Sequence.seq" /outputToStd
IO /quit
faces\Simple\CVI\Source Code\x64>Execution 'Single Pass - Computer Motherboard T
est Sequence.seq [4]' ended
Status: Passed
Note that you'll need to take a little extra work to suppress any dialogs (like the log-in log out dialog).
It's also possible to send custom commands if you need to - I wrote a few examples of this a while back:
CVI Example
.NET Example
LabVIEW Example
Another option is to write a basic command line app that doesn't use the TestStand UI Controls, and just use the TestStand API to call Engine.NewExecution().
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(3,128 Views)
